Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
02.05.2006, 09:18 PM
Poo. I did a Google search and didn't find any such programs, that's why I made mine. If I had known, I wouldn't have bothered.
As to the .5 mph difference, I have no idea since there is no source code to compare to. Since they are so close, I'd say it's a rounding error or something equally simple. I'll check mine over and keep the precision high until it needs to display the output.
Similar to the executable version, in the source of my version are provisions to add other ratios, except I've split it out a little more by adding seperate differential, transmission, and spur/pinion ratios in case you just change a tranny gear or use a different diff than stock.
I may also add unit conversion. Seems like a decent feature.
Thanks for the feedback MetalMan!
