Can the fan from the regular MMP be added on to the 1S version, or is it a different case? I haven't been able to find the fan on the CC website, but I'd like to get one. I have small 25mm fans, but I would much rather have the clean look of the Castle fan with the plastic shroud.
It's a 1s esc . There should be no reason you need a fan . Thats why castle did away with the fan .
It is not only a 1S ESC. It is a 1S->6S ESC that has no built-in BEC and really neat solder posts so you can replace the motor wires whenever you want.
