02.14.2010, 02:17 AM
You must have posted while I was writing my post and I didn't see it. Yeah, if the RX pack allows the system to work, then the connector orientation is ok. Sounds like the ESC BEC might be bad. If you continue to run the Rx pack, I would remove the red wire in the throttle cable just so the Rx voltage doesn't "fight" the BEC voltage.
