JVille
02.27.2010, 05:55 AM
Hello!
I decided not to start a new thread. Brushless conversion has been ready for a few months now. I decided to post some pictures as I have noticed by looking another threads some people would like to see how the part looks when it is in the car.
Almost everything for this conversion was ordered from rc-monster.com. I decided to keep the mechanical brake and change the 2-speed system to center differential.
Parts used for conversion:
IS009 center dogbone (Local Kyosho shop)
Hobao center differential (used)
Mamba Monster Combo 2200 Kv (RC-Monster)
Hyperion G3 CX 5000 MAH 5S 18.5V LiPo (RC-Monster)
Battery Tray Kit Inferno GT2 (RC-Monster)
Brushless Motor Mount Kyosho (RC-Monster)
Double servo and receiver tray for Kyosho Inferno GT (RC-Monster)
5mm bore, mod1 pinion 14T (RC-Monster)
I didn't notice that I will need a brake spacer due to mechanical brakes, so I didn't order it. So it was time to use the dremel. I will probably order later the rc-monster one also.
I use the 14T pinion as a starting point. This was a suggestion from Castle's Joe Ford. At the moment I have been only possible to drift with a car in a small space and all I can say is that motor didn't generate heat almost at all. Motor was something like 35C.
So here are the pictures of the conversion:
Hopefully this post will help someone. Don't be scared by the Perfex servo on brake, it will not stay there.
JVille
