nativepaul
nativepaul's Avatar
03.20.2010, 05:26 PM
They maximums are all different from manufacturer to manufacturer but in general getting a motor above 80degC electronics above 70degC and batteries above 60degC puts them in serious danger of damage or at least reducing their life.
As for optimum temps motors and ESCs would work best at about -10degC the cooler the better but you don't want to freeze the electrolyte in the caps or make anything too brittle and I know epoxy goes brittle in my domestic freezer at -19degC,
batteries are a different kettle of fish, NiCads and NiMh are best used warm of the charger at about 40degC and LiPos are weird giving there best at about 60degC their maximum allowable temperature so it depends on how they get to that temperature, if they start off at an ambient temperature of say 20degC and reach 60degC from the work they do then that is too hot, but if you preheat them to 60degC and they are still the same temp after running that is ideal and you will be getting the highest voltage from your cells that you can get throughout the run Also while no battery likes being used cold LiPos especially don't like it and using a cold LiPo at high current in winter can puff cells before they warm up in use whereas during the summer your more likely to puff on at the end of the run when the've given as much as they can and are getting too hot.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
