Drifted Demon
03.23.2010, 06:56 AM
Originally Posted by skellyo View Post
Correct, you can't just swap two motors wires on a sensored motor. You should be able to swap rotation direction with the Castle link though.
Correct, castle link allows you to change motor direction. So re-solder those wires & double check the sensor wiring while your there....
