jchrisj
03.24.2010, 02:27 PM
Originally Posted by ratpower396 View Post
if you change the gear ratio it will change the rpm which in turn changes the shift point.. If you adjust the shift point it will be back to normal..
Thanks for that, but i realisd..............2 weeks later...........the gearing was out. as soon as i put the proper cog on it was back to normal.
Chris
