Pdelcast
Pdelcast's Avatar
03.31.2010, 05:39 PM
Originally Posted by nuz69 View Post
The defaut timing in Castle controler is 10. But I still dont know if it's the most efficient setup with 1515 1Y 4 poles motor... Can someone from Castle Staff answer or ? I will maybe ask the support directly :)
The default timing works very well with a Neu or Castle/Neu motor. Setting the timing lower will reduce top-end, but give a little more efficiency. Setting the timing higher will increase top-end, but give a little less efficiency...
Pretty simple really.
Patrick del Castillo
President, Principle Engineer
