03.31.2010, 08:20 PM
No (fan issue has been covered extensively- hit the search feature for info ). The fan uses a special plug so you'll need to do some soldering to swap it over with the plug on the broken fan. I think the fan is 25mm square vs 30mm, but like I said, check the castle section a bit more for better info.
Over gearing heats up the esc, rather than undergearing.
