bryan
bryan's Avatar
03.31.2010, 08:47 PM
Originally Posted by AMorgan View Post
Man, this is a bit of an eye opener. My heli servos can pull 2.2A each. Had to get a CC BEC Pro to handle the amp load (shut down in mid-air = epic fail). I suspect most properly adjusted car servos are under an amp.
Heli servos should also be able to be properly adjusted to correct the "amp load" Are Your servos constantly pulling amps if there not on an on/off channel,not sure .Plus you are probrably fighting alot of force from the main blade/ pending the size of your heli? I cant see shut down in mid air being less than very expensive.
