Pdelcast
Pdelcast's Avatar
04.01.2010, 09:03 AM
Originally Posted by nuz69 View Post
Ok thanks Patrick.
But the exact number for the most efficient ? 8 ? 7 ? 5? 0?
Timing of about 2-4 will work best with the four pole Neu or Neu/Castle motors. They will accept more timing, but will run a bit hotter.
Well, I wish I could tell you exactly, but it changes based on load, RPM, and voltage. High RPM setups (6S, low load) will get maximum efficiency with a little more timing, low RPM setups will get maximum efficiency with a little less timing.
Patrick del Castillo
President, Principle Engineer
