Semi Pro
Semi Pro's Avatar
04.04.2010, 04:16 AM
Hyperthetical question:
If you knew that Castle would replace your 6mm rotors regardless ( their error/ omission on the original listing ), would more of you be inclinded to have a go at grinding the shafts down from 6mm > 5mm ( all thats required is a vice/lathe & a dremel/file afterall, and it has been done by a few guys already with great success )?
Given the choice/dilemma I'd grind those shafts baby- 4 months is a long time to sit around whining about something you could fix is less than an hour with basic hand tools & little chance of messing it up ( little by little, check with calipers and/ or the pinion until it fits snuggly ).
the only reason i havent is because i have bad luck and i know it would quickly fail for some unearthly reason and i would have to buy a new rotor for an ungoddly amount and then i would have a taste of the power so i would do it all again only to have the same luck..................... as you can see i have owned alot of mazdas
