Go Back   RC-Monster Forums > Support Forums > Team Tekin
itbvolks
04.08.2010, 01:24 PM
I'm actually setup running cityblocks right now as well. Light weight and solid tread pattern. I had run bowties for years with good success so it'll be interesting to see how these work.
That being said, your clearly not running a heavy wheel/tire combo so that shouldn't be contributing to the heat issues. 175 is HOT regardless. 130-150 is about right with 160's being the absolute limit I'd be comfortable with. Too many rotor failures to be running them real hot. Plus, as nuz mentioned, your efficiency goes away as the motor heats up.
I gotta believe the 1700kv truggy motor makes more than enough steam to power a ~10lb race truck without significant heat issues. I guess I could see you pulling some serious current running in the grass or something but on the track, I gotta believe the load goes down significantly.
Any idea what your pulling for current? I could see some 150amp spikes causing some heat but like I said, in the dirt..... Going down a tooth or two on the pinion should keep the load on the motor down and thus the current draw (and so the heat). I'm hoping you have luck with your wiring rework. Keep us posted....
Ellwood BL
04.08.2010, 10:41 PM
Itbvolks, I ran today at the track with temps being at the hottest 145 on the motor. It must have been that bad solder joint. Let me know what you think of the AKA City Blocks once you run them. I will say one thing about AKA rims, I am not sure they are the greatest for strength. At the outdoor track I run with big jumps, I cracked both of my rear I-Beams. Also let me know how your rims hold up.
Nuz69, the sensored does make a difference at all times. No matter what speed your at the throttle and brake are always the same meaning that 1/2 throttle is always 1/2 throttle and the same for the brake. A great example is jumping. Sometimes in the air the MMM wasn't always the same for correction meaning full brake would sometimes half correct an upright jump and sometimes it would make it nosedive. With sensored it is always the same due to the sensor knowing the position of the rotor. I had several hardcore racers drive my truggy and they all said how much smoother it was than the MMM. Just my .02 cents.
