Thread Tools Rating: Thread Rating: 24 votes, 4.83 average. Display Modes
snellemin
2 KiloWatt RACER
snellemin's Avatar
04.14.2010, 09:42 AM
Sweet mod man.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
SpeedAssault
SpeedAssault's Avatar
04.14.2010, 06:13 PM
Sweet mod man.
Thank you !
Sweet RC body. what is it called, made by ?
I plan on making one like that in 1/5 size
04.15.2010, 12:20 AM
Hi there,
great work you got going here, just throwing a body into the mix- Mercedes C291, it has the look your going for. Here is the site of the custom company using the body in their 1/5 bl as well- http://www.modelconcept.fr/?cat=5
Not sure about the wheelbase or anything though.
SpeedAssault
04.16.2010, 03:51 PM
Originally Posted by Brushless View Post
Hi there,
THAT Is SICK !
good find, thank you
I wonder how much that body would cost ? at my rate it will be a long time before I can mold a body.
SpeedAssault
10.25.2010, 10:49 PM
Updates
Needing new shafts . ( keep breaking)
Installed my custom adjustable brake button on the DX6i (silver tab on the grip behind the throttle)
NEW Tires !
Reinforced the chassis
New upper chassis rails
New Aluminum motor plate
Moved the Motor and battery to left side for better weight distrubution
Results were great !
I was able to drive it with the huge body on it and reach 58mph before it STARTED to FLY up into the AIR !
what happen I think is the rear stub axle broke which could have aided in the front lifting. Happened so fast the front was an easy 10 inches off the ground before I released the throttle
Just before new mods were done
Added a 2 way momentary button with a switch so I can select if I want momentary on or off.
After Mod, the new momentary for mixing activated by my thumb located below steering behind black 3 way switch behind the trigger
