itbvolks
04.19.2010, 06:08 PM
Ya, I'd think based on the mounts in my MBX6T, the runout should be nill but it's something with the slipperential itself I believe. Could be the teflon glide ring. Not sure at this point.
That said, I'm going with the 50T Delrin version Mike is offering now. I don't tend to run the slipperential loose so I don't think heat will be much of an issue. I was just curious if you've seen/had wear/stripping issues with the plastic gears?
Does require a slight gear change going from 16 to 17T pinion for the added 4 teeth on the spur. Hoping it works out well...
Yes, RX8 combo seems very well suited here. Temps were very well controlled and power was very good for my app.
