Semi Pro
Semi Pro's Avatar
04.19.2010, 10:08 PM
What voltage are you running?
Also, what connectors are you using everywhere? Stock 6.5mm on the 1717 I suspect?
I use low start power on the MMM. I don't think this will affect the outcome much but just a suggestion.
yep 6.4mm
I'm running 5cell 18.5v
my next chance to take it out will be wensday, i will change the start power and see if it helps anything, I'm also going to shorten the motor wires about 1 inch, thats about the max i can remove without worrying about them rubbing the rear brace.
most of my running was done in very short mostly dead very dry grass in a park
