05.17.2010, 11:02 AM
Hmm I'll have a look at my setup as only used the space in the arm not an extra one on the outside...
Finnster
KillaHurtz
Finnster's Avatar
05.17.2010, 01:49 PM
Mine would not fit in the std mounting location, as the sring would rub the upper arms. Then again I have the adj arm kit, so IDK if that makes a diff or not. LMK how it works
JThiessen
JThiessen's Avatar
05.17.2010, 03:24 PM
Something is backwards then - I had to use the spacer on the outside. If yours clears, post up some pics of how they are mounted....might save us all some grief!!!
05.18.2010, 08:26 AM
I'll try to get a picture up tonight but I double checked last night and I have no clearance issues with just mounting the shocks to the outside of the arm.
I am using the FLM towers with the LST2 shock mounts and everything just seemed to line up...
JThiessen
JThiessen's Avatar
05.18.2010, 09:46 AM
I think I lied to you - mine are mounted behind the axle, the spacer on the bottom goes inside of the arm.
http://www.rc-monster.com/forum/show...&highlight=FLM
