I think he means you just cover the CF with tape on one side, lay the part your are copying onto the tap, then trace around the part onto the tape. Then you use your dremel/ router / files etc to cut the CF to match what you've drawn- making sure to accurately mark the hole locations.
Im still not nice though- you should see me in action on BYT; them noobs be thoroughly cooked....
