oooooooweeeeeee brushless boy... what is that you are mocking up? Looks pretty good... Uses the standard mounting points... And it looks very robust too!!!
Just one little thing... According to your drawings, if i am correct regarding the motor... You have to fit the motor first then fit the pinion? as the pinion cant fit through the hole already fitted to the motor shaft? Or am i looking at it wrong?
