06.01.2010, 01:41 PM
Any your eye's ;)
most imp't IMO
jamesban
06.01.2010, 01:52 PM
Im going to try to put the shaft ina vice with just a little bit of the flat part sticking up out of the top of the vice and use a file to try and get it straight this time.
06.01.2010, 04:02 PM
Be careful to not mark up the shaft to much in the vise...you will not get the pinion on if you do.
I wrapped my motor w/a cloth then put the whole motor CAREFULLY in the vise so the shaft was sticking completely out...then as stated above used a plastic bag to poke shaft through then ground flat spot
whitrzac
Can't catch this...
whitrzac's Avatar
06.01.2010, 04:30 PM
can you put the pinion on backwards?
