Semi Pro
Semi Pro's Avatar
06.05.2010, 09:17 AM
Originally Posted by FG101C View Post
Did the winding wires get squeezed together? I had one of the first Tekno/NEU's, before they put grommets on the wires at the can. It did pretty much the same thing.
it has the grommets, i opened it again this morning and looked at extensively, all the windeings that are visable look fine, i removed the wire grommets to, the wires look fine under their, bearings are great, rotor has alittle magnitisim but no where near what it should ( not a suprise after seeing the temp)
i know the heat killed the motor but i dont understand why it went from fine to dead in 30 feet
oh well, its going back to neu monday morning
i will update you guys on what Neu has to say about it
