Pdelcast
Pdelcast's Avatar
06.15.2010, 12:19 PM
Bearing failures are extremely rare on the 2200 -- we use a high quality NMB bearing on the 2200 motors.
If a bearing failed after just one run -- immediately after another bearing failed in the same setup, I'd be a little suspicious of the setup, and I'd be concerned about the original rotor. If the rotor is bent (even a small bend) the bearing will fail.
Did the rotor get replaced as well?
The new front end cap doesn't change the bearing housing dimensions or tolerances.
Patrick del Castillo
President, Principle Engineer
