nitrostarter
nitrostarter's Avatar
06.23.2010, 11:20 PM
Actually, the 720i has a 250 watt max output which is 5 times what you currently have. The 720i is a super nice charger and wil require a hefty power supply to be able to push those charging numbers. I'd suggest at least a 30amp ps.
The DUO 615 is really nice! I use this charger since I most run a bunch of 2s lipos. It makes charging easier than lugging around 2 chargers. The DUO will push 180 watts through each channel. However, i'm pretty sure you can sync them to ccharge 1 larger pack at 360 watts output.
There are some other nice chargers out there as well. I tried the Hyperions and loved them, so that is what i use.
N. Rustler conversion
