8ight-b 2.0 tekno conversion doesn't work ???
stum
8ight-b 2.0 tekno conversion doesn't work ??? - 07.03.2010, 08:23 AM
I installed my 8b 2.0 conversion last night and found a little problem, the PROVIDED 14t bell won't mesh with the spur properly with out cutting away 3-4mm of material off my center diff, and there is no using a 13t or 12t as this bell is within 1mm of the brake disc as well... why wasn't this tested? Why did the directions not say you cannot possibly make this work with out hacking up your center diff mount? I'm not use to so many issues, your version 1.0's went together great. Did I do something wrong? I"m not sure how I possibly could have.. didn't anyone test out the castle/tekin mount to make sure it would fit?
PS your countersinking for the main large screws are still all off and they don't any of them sit flush with the chassis.. (f/r/c diffs etc) great looking chassis though. This I'm actually not surpised on, as both your 8b and 8t 1.0's were messed up too and the screws were not countersunk to the correct depth.
