Drilling stock gears
mmdooley
mmdooley's Avatar
Drilling stock gears - 02.21.2006, 02:03 PM
Hey, has anyone tried drilling a stock traxxas pinion gear out to 5mm???
Dafni
Dafni's Avatar
02.21.2006, 02:09 PM
Haven't actually tried, but I got the suspicion they might be hardened.
I had some Kyosho pinions on a lathe, and my drill bit didn't like them, to say the least.
We live and learn, they say.
HotnCold
HotnCold's Avatar
02.21.2006, 02:10 PM
The problem with that is that when you drill the hole to 5mm - there is not enough "meat" where you screw the set screw down to the shaft - It will strip - there is only like one or two threads - It will not work - been there tried that - there are some websites that sell 5mm pinions - they are drilled - and dont work either. I wont mention the site though...:005: :005: :005:
Hows that "Hope and Change" working out for Ya???
Serum
Serum's Avatar
02.21.2006, 03:20 PM
It can be done, best way is to get it done with a lathe. with a drill, it is pretty hard to get the hole in the center. like Hotncold says, the meat for the setscrew will suffer badly. (when you have got a lathe, you could make an extra steel ring, that goes around it )
coolhandcountry
coolhandcountry's Avatar
02.21.2006, 03:23 PM
It don't work very well at all. I have tried this and threw some of the pinions away. You can drill the hole off a touch and have a wobbly pinion to.
Serum
Serum's Avatar
02.21.2006, 03:31 PM
that's the reason you should do it with a lathe Leroy!
mmdooley
mmdooley's Avatar
02.21.2006, 03:36 PM
I don't have a lathe but I know someone that does. Yes Dafni I do believe they are hardened. And you are right Hotcold there won't be much left for a set screw but Serm has a good idea about the ring. I think I will see if my friend will try it and if it's not to much trouble I will have him do a few extra. Thanks guys for the input. :027: Ain't it amazing how some people can agree with everyone :005:
squeeforever
squeeforever's Avatar
02.21.2006, 06:22 PM
well i tried it the other day and it didnt work at all. i think you would be better off just getting some from mike. the slighted bit and it will wobble very badly.
maxxdude1234
maxxdude1234's Avatar
02.21.2006, 06:24 PM
I've got some modded 1/8" to 5mm pinions that have little steel rings around them, used them with my old dewalt 820. The pinions didn't look pretty, but they did they're job very well
HotnCold
HotnCold's Avatar
02.21.2006, 06:30 PM
I agree with ya squee - Thats one part that you dont want to fail -
poconoblmaxx
poconoblmaxx's Avatar
02.21.2006, 07:32 PM
Its not hard to do with the right cutter. I used a 5mm counterbore bit with 1/8 pilot. Did it right in the drill press, the pilot keeps everything centered. Then I just used 680 loctite to keep the pinion on the motor shaft. Only bad thing was the cutter cost $15 and broke after 3 pinions.
HotnCold
HotnCold's Avatar
02.21.2006, 08:13 PM
Yea - why would you wanna just buy a 5mm pinion and be done with it - Drill press, collars, counterbore bit, and replacing cutter bit, and the time to do it, - sounds like a lotta work for a couple clicks on the mouse, 12 dollars, and new pinions a couple days. But thats just me....:dft008:
