Jahay
07.06.2010, 10:30 AM
I really like your mounting method!!! REALLY LIKE IT!!!! it is secure, strong and has complete support over the motor.
These other methods such as using bolts to screw into the motor still continues to worry me! From some of the landings i have had, i doubt that two screws would be able to hold my heavy 1520 motor from the hard landings and cart wheels.
Thank you for your idea... im just going to have to see if it works with my TVPs... if not i will have to work my around it. (this is also a cheaper option than buying the RCM Mount!
It also means you are not limited to what spurs you can use and there will be no shimming problems... Looks like the best option...hmmmm
