georgec
georgec's Avatar
07.16.2010, 11:45 AM
Originally Posted by stampy View Post
why use a soldering iron. i use a propain torch. heat up the bullet connector feed in the solder so it fills about 2/3rds of the connector and just stick the wire in there continuing to hold the flame on the connector until the wire sucks up the solder and your done :) ive found its the easiest way for me.
I like this idea! I have a small jewelers torch that should work quite well.
