Thomas Porfert
Thomas Porfert's Avatar
07.20.2010, 10:34 AM
@Nuz 69: You're running a 4-pole motor, so you will need to divide the result by 2.
If I understand the setting correctly, because it's limiting the torque of the motor, it will supersede the effects of punch control; which is more of a voltage/RPM limiter. (correct me if I'm wrong Pat)
I'll let the engineers know about the issues with the torque control start-up.
The fan should not be running the entire time, torque control should actually reduce motor and ESC temps. Not sure why, but that is what I was told be Richard (our software engineer). Hopefully Pat can shed some light on the how and why.
I'll check with Richard and find out why the fan is running continuously. Was it a Mamba Monster or Mamba Max Pro??
@Fg101C: Did the problem persist when you turned off torque control? Or did you have the issue with it turned off as well?
Thomas Porfert
Castle Tech Support
