Nard Cox
n00b
08.04.2010, 10:40 AM
Also been playing with that idea but the fact remains that it will have a very small contact with the actual bullet and a lot of solder will still be needed.
JThiessen
JThiessen's Avatar
08.04.2010, 11:11 AM
Buy some bullet connectors that have the additional hole in the side (meant for 90 degree joints).
08.04.2010, 01:09 PM
Nard- Don't be afraid of soldering your motor. Solder is our friend!
You won't overheat or wreck anything by soldering. Anything you do solder can be de-soldered and put back to normal.
Connections need to be SOLID. Solder mechanically locks the connection in place, and helps to make a good connection.
Learn to solder. It use to intimidate me too, but I just practiced and now i do my own soldering. There are lots of useful youtube videos showing how to solder. Good Luck!
