Stoomstrijkijze
08.17.2010, 03:31 PM
+1
Most of my 2 pole motors don't see more than 5 degrees of timing advance and my 4 polers are maxed out at 8 degrees.
Only my roar stuff sees more timing at times. Why, because they need it. But I don't run them much as they run way too hot.
Quote from Tekin about their T8 motors:
Max Timing will raise the kv of the Y wound motors 150 to 200.
Max Timing will raise the kv of a Delta motor 100 to 150kv
I guess this is also true for the Neu/Castle/Tekin 4 pole motors cause I heard they are all based on the original Neu motors.
