BashemSmashem
08.18.2010, 02:57 PM
Well , I also went too the LHS and picked up a CC 10a BEC , put it in and it seems to have cured my problem ? So why cant the BEC in the Mamba Max Pro do the job ? Is there some kind of fault with them ? I am using a high torque servo (JR 9100T) but I use that servo in all my 1/8th scales and the MMP ESC is the only one that is giving me trouble .
Stoomstrijkijze
08.18.2010, 05:42 PM
That servo is known to be a current eater
kingdomracer
kingdomracer's Avatar
08.18.2010, 08:12 PM
I'm following but what I want to know is; if using the 7950TG and MMP with a 2s setup could you get away with just adding the 10,000uf 10v cap or should you still put in a CC BEC because of the HV servo. If that's the case would changing the servo make then an external BEC unnecessary?
JESUS says "Fix it B4 it Breaks"
bryan
bryan's Avatar
08.18.2010, 10:25 PM
I personnaly would rather have a cc bec on my ten than a cheesey servo.
just my .02
kingdomracer
08.18.2010, 11:47 PM
I guess I should've been more specific. I was thinking instead of using the 7950TH to switch to my 7955TG which isn't HV. In that case would I still need an external BEC on 2s? And is it ok to put say 3 x 4600uf 10v caps in series to be closer (well actually way over) to BrianG recommended 10,000uf 10v? Thanks BrianG for a reply.
bryan
bryan's Avatar
08.19.2010, 12:32 AM
i actually had problems with a similiar servo.Not the hitec 7955tg,but the hobbico ct170,or cs170,anyway basically the same servo per the specs.So i would say no. BEC should solve your problems.Buy the cc bec pro so we can get some feedback on it.I've been concidering one.
kingdomracer
08.19.2010, 01:06 AM
You buy Hobbico servos and use the word cheesy in your other post
And please post help according to a person's application. I'm using a 2s setup why would I want a CC BEC PRO that doesn't even make sense. Like I said I'll wait for an answer from BrianG, thank you!
Stoomstrijkijze
08.22.2010, 04:04 PM
It's safe to run the 7955TG on 2S unregulated lipo. It's the same servo as the 7954SH but with titanium gears instead of steel gears.
08.22.2010, 05:50 PM
No thats a 7950TG.... A 7955TG is a 6V servo...
