Serum
Serum's Avatar
02.24.2006, 06:33 PM
If you are planning on running 32 cells, you might consider selling the schulze and take a bigger one. Takes away some risk for sure.
I too think that the 3.5mm plugs are too small. I contacted MGM about it, and i was told that it was more relavant for boats, because boats take a higher constant current.
On the other hand, i like the idea of a loose cable between the motor and the controller. (lehner 19/22 series no high-amp) these motors also use plugs.
