MetalMan
MetalMan's Avatar
02.26.2006, 04:33 PM
I've heard this problem is with the low cells counts where the battery's voltage can't stay high enough to give enough voltage to the Spektrum RX, causing it to cut out. In other words, make sure you are using good cells with your SS5800 systems. I'm sure that shouldn't be too hard for you though ;).
