Stage one
XXXDAD
XXXDAD's Avatar
Lightbulb Stage one - 06.30.2010, 04:59 PM
Removed everthing and installed the Slash 4x4 RPM front bumper the two holes match perfect!
Click on the pic to make it bigger!
Next are the 12mm hex drives for adding the neg. 10* Proline Protrack Wheels to get me to the desired legal with:
http://www.impaktrc.com/product_info...oducts_id=5655
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
Rear Ten Build
XXXDAD
XXXDAD's Avatar
Lightbulb Rear Ten Build - 07.06.2010, 03:48 PM
Click on them to make them Bigger!
RPM Slash 4x4 Rear bumper Installed and the Aarms fliped!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
XXXDAD
XXXDAD's Avatar
Lightbulb 09.21.2010, 09:19 AM
NEED SOME INPUT... WHAT DIF OILS ARE YOU USING? AND GEARING? I want to use a GTB / 4.5SC Tekin combo on 2's.... had to take a break and i'm going full force again! I need a Conversion!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
XXXDAD
XXXDAD's Avatar
Exclamation 09.26.2010, 12:40 PM
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
XXXDAD
XXXDAD's Avatar
09.27.2010, 10:59 PM
Gonna try 7/10/3 Difs
Shocks:
Front- 42.5 oil Gold spring piston drilled w/55 bit
Rear - 37.5 oil Black spring piston drilled w/55 bit
17 pinion
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
XXXDAD
XXXDAD's Avatar
Exclamation 10.14.2010, 04:22 PM
Shocks:
18 pinion
TEKIN RX8/5.5 SC AND THE CONVERSION ON THE WAY
NEW PAINT ON THE BODY AND IM ALMOST THERE...
POSTING MORE PICS THIS WEEK!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
XXXDAD
XXXDAD's Avatar
10.21.2010, 07:17 PM
PROJECT IS MOSTLY DONE NOW COME'S THE TEST AND TUNE: CLICK ON THE PICS TO MAKE BIGGER
NOTE: RCMONSTER E CONVERSION POLISHED!!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
GO-RIDE.com
12.02.2010, 05:53 PM
Great job! What body did you use? I thought the Ten-T wheelbase was about 1.5" shorter than most SCs, but that body seems to fit the conversion perfect.
E-8ight - Tekin RX8 2000kv/4S
lucias
lucias's Avatar
12.02.2010, 07:10 PM
I picked up a used roller and have been planning on converting but couldn't decide whether I wanted to convert it to a short course truck.. you say you flipped the A arms? what did you do and why?
