Thread Tools Rating: Thread Rating: 32 votes, 4.94 average. Display Modes
09.28.2010, 04:28 PM
Well, that's weird. I did a quick search and the stickers I saw didn't say that. It should work fine then.
If you have a positive and negative supply rated for the same current, you can hook up your load across the two; load+ to supply+ and load ground to supply-. You see that all the time with regular power transformers: you'll have your main outputs, but then also a center tap. If you use the center tap you get a + and - supply. But if you just use the main outputs (not center tap), you get the full voltage. RadioShacks transformers are like this. Like their 12v models; they're rated 12.6v, but if you use the center tap you get +6.3v and -6.3v.
