09.29.2010, 04:09 PM
By the way, I added a spear gear data table to the calc (under data tables). It probably doesn't have all the vehicles in this thread right now, but it's better than nothing...
MiniMGT
09.29.2010, 10:58 PM
I'm pretty sure the MMGT is 32P.
Is that what you used in your electric coversion? (You did do a conversion to one right?)
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
09.30.2010, 12:27 AM
Don't listen to this guy!
The MMGT IS Mod 1... I just went and dug out my extra parts from the conversion and checked.
MiniMGT
Thumbs up 09.30.2010, 01:00 AM
Thanks for that
Snowman 78
5,280 feet above sea level
Snowman 78's Avatar
10.01.2010, 12:59 PM
I have a DuraTrax Vendetta S.C, it uses mod .6 gearing I want to use my Novak Mongoose Brushless system in it. Motor has a 1/8" 3mm shaft, stock motor uses 2.3mm shaft so I need a new pinion gear. Can I use a Metric 48 pitch gear? (Mod .5292)
Brushless Rustler
AX10
Venom Creeper
Slash 2WD
Slash 4WD
