kingdomracer
kingdomracer's Avatar
10.09.2010, 11:48 PM
I run a MMP w/1512 1.5Y Castle-Neu motor with no probs on 4s.
However I had to install a CC BEC to run a 7945TH.
My install of the CC BEC is different than the instructions, I still use the internal BEC from the MMP to power the radio and transponder.
While the CC BEC just powers the servo. I use a Y-adapter for the CC BEC and servo with the red wires connected to each other on the servo/bec side and the part that goes into the radio the red wire is disconnected. This is the ONLY true fix for using the MMP with a high voltage servo before going to a CC BEC PRO.
JESUS says "Fix it B4 it Breaks"
crusey_aus
11.04.2010, 08:12 AM
Gday folks,
Installed the MMM / 1512 (1800kv) today in my Slash 4x4 and I love it
Running 4s at the moment but will try 5s in the next few days
However the bec doesnt seem to be coping, my RX voltage is dropping to below 5v (running an ACE DS1015 servo) but not browning out
Will install an external bec to rule it out
Cheers
