whitrzac
Can't catch this...
whitrzac's Avatar
10.30.2010, 08:44 PM
so the wire that goes to the reciver riped out of the esc?
it shouldn't be too hard to resolder it
I'v never soldered on a MMM, so I'm not sure how tight it is inside the case...
simplechamp
simplechamp's Avatar
10.31.2010, 12:11 AM
You just remove the whole ESC board from the case. It's not an issue of getting in there, just that it can be tough to solder those small wires onto the tiny solder pads without shorting between them with solder or overheating the pads or nearby components.
