What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.01.2010, 09:41 PM
Sounds like overdriving the front would benefit on-power handling. Other than that, the CD would take up the slack between the F/R diffs.
Overdriving the rear just sounds like fun. Although it might help the drifters.
Semi Pro
Semi Pro's Avatar
11.02.2010, 02:12 AM
if you really want to drift. toss a oneway in the front and a spool in the back, that alot of fun
11.02.2010, 06:33 AM
It should also be noted that overdriving in any way (cd or solid center) will wear the gears faster. It is just easier on the driveline if everything rolls together.
The only application where I would consider overgearing would be in mud, where the loss of traction saves the gears, or in rock crawling where the slow speed saves the gears.
(or racing an xxx4 where winning is more important than money)
