8th scale Stunt-Driver/Mechanic
11.12.2010, 04:40 PM
Is that an Aston Martin body? Its looks like the new camaro... Looks Real nice though!
I almost bought some revo shocks to throw on the front of the car, then put the front shocks in the rear... But the same zip-ties have been holding up for 2 months now and they are only $.04
11.12.2010, 04:44 PM
Honestly did not pay much attention to the body style when I got it. Had the same set up w/the zip ties...but stumbled across the Revo shocks on another forum for $ 15- shipped so I could not pass it up
11.12.2010, 10:28 PM
Is that an Ofna GTP bumper on the MBX? Also those body mounts are very nice! they must help hold the body up great!
Mine seem kinda weak, but the car has cartwheeled and tumbled at high speed and its held up perfectly, especially for Maxx and stampede body posts. My dads GTP posts actually broke quite frequently. ( but he did hit a curb at 3/4 throttle and his car litteraly flew 10-12' up and a good 20' out before rolling like crazy!  It was quite a site!) he needs to get another set...
Looking again, I really like that body and paint scheme you have! Cheers!
11.12.2010, 10:59 PM
Thanks for the kind words. The body posts do hold up well. As far as the paint goes....it was done by a member here whom I will not name due to the fact of other multiple members having issues with him. In fairness, he did a great job on the body.
11.12.2010, 11:03 PM
awww, I recall... Looks good regardless the timeframe....
11.19.2010, 02:20 AM
11.19.2010, 04:01 PM
Yeah pretty tough. Good thing your shocks didn't bend. Did it bend your CVD?
I'm glad you found a dog bone that would work.
11.19.2010, 04:07 PM
It may have bent the CVD, the wheel was wobbling pretty bad. But it could be the wheel, bearing, CVD or all of them . So maybe more than $7.00.
I didnt think it was that bad of a hit. But daaaamn.
12.16.2010, 11:47 PM
Well The Cvd Was Ok, The other side was a bit bent though  FLM Arm should be here tomorrow.
Got some "teaser" pics. Here is my Old "Mr. Crash style" 1/8 CD cup I had in the Tranny a while ago. Only lasted about 4 packs... Can you spot the problem???
Bottom Steel plug failed....
Solution:
Nova-RC Diff cup... Personally delivered by the owner...  ( I actually met her at the Grocer)
This will not be going in the Transmission. I bought some 1/4" 6061-T6 to make a CDmOUNT I bought a new 8ight diff and will use all new parts... Except maybe the spur... I have a kyosho 44t spur and It fits like a glove on the Nova Cup.  It didnt fit well on my 8ight buggy CD for some reason and leaked like Crazy...
12.19.2010, 11:05 PM
12.20.2010, 12:52 AM
Great brother! I just want you to know I'm keeping up thats all.
-Zack
12.20.2010, 01:48 AM
 Thanks! I am glad someone is enoying it!
Wont get the Aluminum till Wednesday for the motor mount side. But Today I did make the bottom mount for the whole CD assembly.
I cut up and old 8ight chassis (where the CD would mount) and shaved it square to mount snug between the chassis rails. Then I will bolt that whole thing down to the skid plate.
Here I just took a pic. So much easier to see then then imagine.
12.27.2010, 11:55 PM
12.28.2010, 12:04 AM
I will add these braces. 1/4"x1/2"x2". They screw into the FLM Braces through the chassis. I still need to tap the end and screw the motor mount to the end. Then I will make an angled piece of 1/8" 7075 to finish it off and make it rock solid.
Here is what I got up to now (minus the 7075 angle and screw tapped in from the motor mount side)
About ~2mm off the motor fins to the chassis: Woot!  Even if I regear to the 50t spur and I can lower the motor down again to keep the motor sitting nice and low...
12.28.2010, 07:55 PM
looks very nice. On my truggy w/the 1520 there is only 3mm clearance with the motor
