Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Krawlin
Got brushless?
Krawlin's Avatar
11.24.2010, 04:53 PM
"LittleMachineShop.com HiTorque Mini Mill is the best in its class. It has the most power, most torque, and a larger table than other mills in its size range.
The 500 Watt (0.67 hp) brushless spindle drive motor provides tremendous low end torque. And you can vary the speed from 50 RPM to 2500 RPM continuously. There are no gears to shift. And, with no gears, the HiTorque Mini Mill is the quietest in its class.
The large mill table provides 50% more table area than other mini mills. It also has 30% more travel in each direction. The resettable feed dials allow you to zero them at any point.
Grizzly Industrial, Inc. sells the Grizzly model G8689 mini mill. The Grizzly mini mill has a 3 Morse taper spindle. It comes with two 3 Morse taper collets; a 3/8 inch collet and a 1/2 inch collet.
Harbor Freight Tools distributes the Central Machinery model 44991 mini mill. The Harbor Freight mini mill has an R8 spindle.
Micro-Mark carries the MicroLux model 82573 mini mill. The Micro-Mark mini mill has a 3 Morse taper spindle. The MicroLux mini mill has one unique feature; the table feed dials both advance 0.050 inch per revolution. On all the other mini mills the dials advance 1/16 inch per revolution. The 0.050-inch per turn is easier to use than the 0.0625-inch per turn of the other mini mills. Micro-Mark will have you believe that the other mini mills have metric dials, but they do not.
Micro-Mark also carries the MicroLux model 84630 R8 mini mill. This mini mill is similar to their other mini mill except it features the 500 watt brushless DC drive system.
Homier Mobile Merchants sells the Speedway mini mill model 03947. The Homier mini mill has an R8 spindle.
ToolsNow.com (Cummins Industrial Tools) sells the mini mill model 7877. The ToolsNow mini mill has an R8 spindle."
Knowing everything above really helped influence my decision. Now if I had the garage space (and a good excuse ) to purchase a large Bridgeport mill, I would have gone that route in a heartbeat, but since I have neither, this small mill is perfect for me. Its very quiet, it doesn't take up much space, has plenty of power, and great capabilities to do what I need it to do. So far, I love it. Here is a list of some pro's and con's I have found thus far with this mini mill.
Pros---
- It's Brushless!!!
- Great specs on the table travel
- Powerful
- Quiet
- Doesn't arrive slathered in that nasty red assembly grease, just a light coating of oil and a mild grease to prevent rust during shipping
- Good price point at $650
- the X-Axis gib is easy to adjust, and the hand wheel has maybe a thousandth of play, if that, and turns very smoothly.
- Even when milling steel, it remains very quiet. The motor doesn't even break a sweat, and after a couple hours of a machining newbie (me) playing around with it, the motor was only warm to the touch.
- 12mm T-Slots, a common size for most mini mills, so clamping kits and accessories that bolt to the table are easy to find, nothing specialized needed other than a clamping kit meant for 12mm t-slots.
- R8 taper spindle is much more forgiving than #3 Morse taper, just unscrew the draw bar a bit, tap it lightly with a hammer, and your collet/endmill holder will drop enough just enough to easily remove the bit you are using.
- Comes with a small tool kit with everything you need to adjust the mill.
Cons---
- The Y-Axis gib is difficult to adjust, and easy to over-tighten it.
- The Y-Axis has a bit more play than I would like, as in, I can turn the handle wheel about 4 thousandths without the table moving.
- Each complete turn of the hand wheel moves the table 1/16th of an inch (.0625), would rather have it so each turn of the hand wheel moved the table .050, would be much easier to do alot of the math this way.
- No metric option?
- The fine feed for the Z-Axis has a good bit of play in it, maybe it just needs to be better lubricated though.
- Probably being OCD, but the axis locking levers, particularly on the Y axis, are in dumb places, where you can screw it in about 2/3 of a turn, then have to pull the knob back and twist the opposite way to reset it on the locking bolt so you can turn it the rest of the way to lock it.
Here are some pictures of it, as well as an old T-Maxx chassis that became a practice part for my first time using the mill -
My set of endmills, 2 and 4 flute
Clamping kit
All cleaned up, small bottle of Pepsi for size reference
Stay tuned, will be posting about my first upgrade pretty soon, a solid mounted compressed air shavings removal system.
Monster GT Conversion
