12.05.2010, 07:33 PM
The tests they actually do are fine, if a little feeble ( 6C discharge test & low load/gearing to test runtime & speed are easily improved ), but its the fact they test dissimilar packs together that creates almost useless comparison charts. All the batts should be the same mah capacity, and they should all be the same C rating too, or no more than ~200mah difference at most in order to create a fair test.
