You'll end up with the same physical number of connections in the end, just different connectors. If you wanted something that could handle more current then EC5s kick ass, otherwise I'd stick with trx plugs really. Does your MMM come hardwired with a series connector ( like the BL edition emaxx and erevo ) or do you have a separate series harness plugged into a single connector coming from the esc?
