12.19.2010, 07:21 PM
If you are not calibrating and have no throttle input then:
Flashing Green OR Red = Speed control has not been calibrated and is not armed; or throttle sub-trim is not at 0.
If you are applying throttle or reverse WHEN calibrating:
Flashing Green OR Red while beeping = indicates speed control is looking for full throttle (green) or full throttle (red). If it continues for more than ~ 8 seconds, indicates speed control is seeing partial throttle (green) or reverse (red), increase endpoints on transmitter so speed control sees full throttle/reverse.
take a look at your transmitter settings, and make sure the rx lead is plugged in correctly/ fully & not damaged.
