01.01.2011, 11:03 PM
There must be some where to get 6mm mod1 pinions nearby europe ? do rcm sell this ?
can rcm-shop please post high detail images, and specifications of the slipperential ?
6mm pinions arent very common, but they do exist:
http://204.186.93.64/PinionsMod1.htm
You could also drill out a 5mm bore pinion if you have a lathe, or there is always http://www.sdp-si.com/ who can custom make pinion gears.
Detailed diagrams of the slipperential arent available due to scumbags copying the design and selling it from China ( they actually bought one and then reverse engineered it, but all the same ). There is a forum section explaining how it works though if that helps: http://www.rc-monster.com/forum/forumdisplay.php?f=45
As for motor & battery choice, it helps alot to know the exact vehicle and what you are trying to achieve with the setup, rather than just working from the known weight and transmission/ differential ratios.
