Manne
01.03.2011, 06:34 AM
Just a small update.
The diffcup from the savage fits on the lst cup and vice versa, the only difference is that the lst cup is sligthly slightly shorter, maybe itīs a good idea for people that is stripping the intrenals on their fluxes to use a lst cup, and for the Lst owners that are stripping internals to use savage internals instead since they are a bit thicker and would make the gearmesh tighter.
I didnīt mount it all up tho, so Iīm not 100% sure that it will fit, but I thought it might be a good idea since you have a limited space to shim the internals on because of the pin that the gear sits on on the output.
