01.04.2011, 12:48 AM
Good info, thanks Josh.
Ok, so now I am at the rear hub carriers. I like the fixed design, and looks like integy is my best bet. Seeing that the difference in the flux and xl are the dogbone lengths, I guess I should order the integy rear carrier for savvy x, not xl?
Which dogbone should I go with? Any benefit running the xl length ones? I am guessing I will have to run xl carriers/hubs if I go with xl shafts?
Why did they make the xl shafts longer? Thought they used hub extenders to get the extra width?
Better to just stick with flux parts? I have a bunch of savvy X suspension parts, guessing those will be compatible with the flux axles, etc.
