josh9mille
josh9mille's Avatar
01.06.2011, 03:09 AM
Originally Posted by DrKnow65 View Post
Yah Linc, small motors don't actually have a regulator, and they are single stage, but the effect is the same. They produce an AC waveform (like a real strong hall effect sensor) and you have to rectify it. But the dwell, peaks, and valleys are the same deal. I found this same situation on the Raptor 80 I put togeather for the kids this summer. If you want it to idle correctly it takes a battery.
Some small motors just use a magneto ignition and are completely void of a charging system all togeather, but that's not what you would find on a snowmobile with an electric start...
so there IS a difference in the stators of say a e-start phazer and one that just has a pull start? Looks like ill be trying to source a battery for it somehow....
