Pdelcast
Pdelcast's Avatar
01.15.2011, 01:20 AM
Here's a good question- I heard the traxxas 1515 motors have a rear endbell with a hole in it so you can see the shaft and bearing, is it possible to use the same design on the regular motors so that the rear bearing can be poked out if it needs to be replaced?
I havent had any issues myself ( touch wood ), but by all accounts if the rear bearing fails then its more or less impossible to remove- a sticker over the hole wouldnt be such a bad thing in my eyes if it makes maintenance easier. ABEC 3 bearings would be cool too vs the standard ABEC 1 affairs that are currently used still unless they've been changed recently..
Long live my/the MMM V1
Hi Neil,
The early 1515s were like that - - and we had a lot of complaints from people that sand was getting past the sticker and into the bearing. Or they would remove the sticker, and then dust/sand would get into the bearing. Or the sticker would fall off, and dust/sand would get into the bearing. So we just sealed it -- it's actually more expensive to manufacture the way it is now.
The rear bearing fails very rarely, because it is under very little stress, and we haven't had any complaints about it since we covered the rear end. :)
Oh- and to replace the rear bearing, you drill a small hole in the end-bell to drive out the bearing...
Patrick del Castillo
President, Principle Engineer
