pinkpanda3310
pinkpanda3310's Avatar
01.17.2011, 10:39 AM
The tires that were on there didn't show the camber was out too far but they also had inserts. I guess solid rubber will show up the tell tale signs more clearly. I will adjust the down stops so it sits a little lower too.
You reduced the rear toe considerably?? i thought drifters had lots of toe. Thanks for your input anyway. I'll keep playing around with the setup.
